Hi there, very long time i did not come to the forum, i was really busy working on other things than console repair.
I need help in troubleshooting what is the problem with a Switch V2 HAD-CPU-01 board (i guess it’s a V2 ? I am rusty after that much time without touching anything).
The console did not have any water damage or so, doesn’t look like someone already attempted anything on it.
The symptoms are simple, no backlight. I can see the LCD working with a torch, the touchscreen is also responsive, if i put the console in a dock, all working good on the TV, but no backlight.
I noticed after removing the battery connector and putting it back that when i power on the console, the backlight works for a brief instant (a second or a bit less) and then nothing.
No-one have an idea ?? Or just a confirmation that the values looks good or bad ? I would also like to change the chip, but i don’t find any with that marking on Aliexpress.
Thanks, i found few other threads mentioning this but i wasn’t sure, since the marking is always different and i couldn’t find another thread with that board and this chip fried. I will order one and see how it goes, thanks.
Hi guys, got the new chip, replaced it, i get a Nintendo Logo with backlight, then that’s it, screen goes black again and backlight do not work any longer until i unplug the battery and restart the console. I am running out of ideas.
Problem solved, this is crazy but the brightness was at the lowest value, which looks like a screen without any backlight I am not sure, but it could be that this was simply the issue from the beginning. I thought i looked at that setting with the flashlight, but now i am not sure anymore. Well, thanks all, at least i revived some skills of micro-soldering, it was a long time that i did not sold anything that small
