Help identifying capacitor near IC Chip
Processing: IMG_E0870.JPG…
I accidentally shorted my switch lite while charging. Checking the continuity with a multimeter I believe the identified capacitor is the one shorted. Can anyone identify the specific capacitor this is? There’s no identification on it. The closest I’ve come to definitive answer is it could be 100pF SMD 0201. I haven’t been able to source a donor board so I was hoping to buy the single capacitor. I also haven’t been able to find any proper board diagrams or schematics for the switch lite.
Thanks for any help you can provide :slight_smile:
Is everything fine now?
It appears the image didn’t upload correctly…
However, if you’re looking to buy replacement components, a couple of commonly used sources are DigiKey and Mouser.
If you’re not already familiar, they both have extensive inventories, as well pretty solid search and filtering options. Usually fairly cheap (depending on region, and what component you’re looking for) to get like a strip of 10, as you’ll most likely want a few extra in case of the inevitable fly-away component.
Digikey: 100pf smd 0201 caps
Mouser: 100pf smd 0201 caps
