Im trying to identify the value of this capacitor. There isn’t another one on the board to get a reading from.
Sorry, im a new user and I can post an image.
Its just above F7502. Its a bit larger than the other ones
The part, at which the red arrow is pointing at, is not a cap, it is a coil.
Thank you! Would it make sense that i dont have continuity? It may be apparent, but how can you tell? They look similar to me..but I havent been doing this very long.
Not make sense if no continuity across a coil, make sense no continuity to ground.
Thank you. I do have continuity across but not to ground. So it would seem it’s in order.
Im dealing with a dead, no beep or light ps5. The psu has 12v. So i started with testing capacitors(well, I guess also inductors) im going to check fuses now.
Thank you. Ill update soon
Not sure if I properly measured. I clamped the black probe to ground and held the red probe to each pin using diode mode on my multimeter
There’s the board, then the orientation of the chip. Starting at bottom left and going around here are the measurements:
1.373 9) 1.228 17) 0.911 25) 0.002
1.373 10) 0.005 18) 0.911 26) 1.374
1.373 11) 1.230 19) OL 27) 1.374
0.001 12) 1.230 20) 2.003 28) 0.910
1.625 13) 1.230 21) 1.373 29) 1.265
1.871 14) 1.374 22) 1.900 30) 1.791
1.875 15) 1.374. 23) 1.228 31) 1.755
1.373 16) 0.001 24) 1.228 32) 0.539
Im not certain how it applies to the image. The numbers don’t really seem to align. Though I may be doing something incorrectly.
In general:
Diode Mode: red on ground and no other power input.
(Background: Diode mode is measuring the drop of an injected voltage against ground. If the probs are not reversed, the consumer in the circuits will start to turn on.)
Pin 1 is marked on the chip with a dot and on the mainboard with an arrow/triangle. Counting is counter clockwise at qfn chips.
Here is my measurments from the southbridge pmic. I would turn your board and the same orientation and compare your readings to it.
I really appreciate you explaining and taking time out for a beginner.
This is how I oriented the board to measure. Starting bottom left moving counter clockwise. This time I used red on ground and black to probe.
Here are the measurements:
There is variance across pretty much every one, which I assume is to be expected. However, I did note that pin 6, 9, 11, 18 and 27 had significant variance.
Please check pin 18 (3.3V_SS_PG2) its resistance to ground.
From your diode mode reading this line seems to be shorted to ground.
Pin 18 measures 002.5
If your 002.5 is a Ohm reading, I guess this line is shorted.
It goes to the southbridge and to Infineon Security Chip.
I would inject 1V 2A and see what current is drawn and if something a cap or Southbridge, Security Chip or the DA9065 is getting warm/hot.
It is an ohm reading. Black on ground red on pin. Im waiting on a bench power supply. Ill update when I can. Thank you again
When injecting voltage, should I connect to the metal connectors that go into the psu? Or would i connect to ground and inject into the pin i have a possible short on?
Injecting for short finding should be at the pin/line which is possible shorted.
