i have a problem, i lost my capasitor in gpu switch,im soldering sxcore, do you know size the capasitor to replace it?
I facing the same issues pls help someone.
could be 0201 1uf (10v) but i dont have a meter to check
Brotos did you manage to fix it?
I’m searching for the solution as well, but mine damaged component located on the third capacitor (???) located on the left side of the ribbon, labled SP1, where you’d solder the two capacitors (not sure it’s capacitor or resistors) – I can’t find any component schematic that would point me to know what to buy for the replacement
Should be ceramic capacitor 1.0uF / 6.3V / 0201
