I blew up a very small thing
Disclaimer: I have no clue what I’m doing.
I was trying to take some measurements and forgot the device was plugged in. There is a very small capacitor(?) near the M92T36 which blew up (like a firework show for ants). Now the switch won’t go to 15v and I only measure 5v where I previously could still measure 15v.
What is this component and what do I have to look for if I go search for a replacement part?
ibb. co/DGDGXFr
Thanks, it appears it is the 10nF one, do you happen to know what size that is? And do I need to keep other things in mind when trying to order a replacement?
size_voltage: 0201_25v
Thanks for your help!
Sounds like you will need to replace the m92t36 if you’ve lost it’s ability to negotiate 15v from the charger
I’m afraid you could be right, I’ve ordered both so hopefully that will fix the original issue I had as well :slight_smile:
