Hello,
Would any of you know what could be wrong ?
iPhone is charging fine with cable, but when wireless charging is used its disabling the cable.
And to enable the cable working I have to disconnect the wireless coil and battery, then connect the cable and battery.
So the problem could be with USB IC U6300 or U3300 charger.
Not sure if that’s the correct forum, but if any of you knows other forums that fix smartphones would be great.
Thanks.
