If you read the Playstation 4 Technical Specifications - Wikipedia->Power Usage section-> 1st sentence states, “The PS4 is powered via an internal wide voltage range (110–240 V AC 50 Hz/60 Hz) switched-mode power supply.” Footnote 72 follow that link to bottom of page and then to the step 15 referenced there.
Finally you could watch a TronicsFix youtube video number C-NtrubxPPE at minute 2:03 and freeze it.
Steve has removed a CUH7200B power supply which clearly states 100V-127V at 3.5A 50/60Hz and 200V-240V at 1.7A 50/60Hz.
I would bet gold that this is definitive positive empirical data that factually supports that your machine will indeed run on 200V,220V,240V at 50/60Hz and not blow up, in fact will run very well.
Your honor…I rest my case.
X
