I was wondering if there is a layout of the southbridge board unpopulated or maybe someone has a picture of the board of U34 IC-PWR TSOT23-8 switching regulator not soldered on so I could see the board underneath. The xbox im working on had this u34 chip burnt and unfortunately it took 2 pads out but thankfully never went into the board. I would just like to make sure I am hooking up to the correct traces when I rebuild them. I know there is a schematic but I need to also know if the the board underneath the chip is 1 trace going under it and out the other side or does it split underneath. Seeing the board without the chip on it would help me out so much. Stinks cause this isnt a hard fix but not being able to see this part of the board it makes it impossible. Thank you to anyone that can help…
