Issues with DualSense after stick replacement
Hello everyone. Yesterday I replaced the right analog stick on my DualSence (BDM-010 board) with a Hall Effect V5 since it had a lot of stick drift. After putting everything back together it first would not turn on, only the orange light was blinking three times (indicating a hardware error). After trying again it did turn on but is behaving very strange. It seems that is is getting constant inputs from both analog sticks and also L2 & R2 all the time. In addition to this as you can hear something is vibrating shortly every couple seconds, not sure if it is the adaptive triggers or the rumble motors but I think it sounds like the triggers.
Has anyone experienced this already and has an idea what could be wrong or what to do? I did check the board already for shorts or solder that could have bridged something. Also all the cables seem fine and undamaged to me.
I do have a video for it:
https://jumpshare.com/s/PDns4HLwOSvc5j2psBQv
Maybe the new stick is broken or not compatible? If so could this cause such issues?
Thanks in advanced!
