Hi all
I have one of the KSGER T12 Soldering stations
I have a question regarding one of the menu options.
Code Tip
It contains two options
First is to select between the temp sensor in the CPU or the handle
Second is a temperature adjustment between 0 to 100
The question is what is the practical difference between to two sensor option, which is the best one to use and secondly what’s the temperature adjustment actually for ? Is just to adjust the actual temp reading for the ambient temp if it’s not reading correctly. Mine by default was set to 25.
Thanks for any help with this
Psul
