anyone know if there are alternative solder points for a hwfly install, on a Switch v2?
I soldered up my flex cable, connected it to the hwfly chip, and the Switch didn’t boot - the hwfly didn’t light up at all. So I desoldered the flex to start over, and in doing so, I lifted the SP1 cap and its pad…
it’s the pad on the right which has lifted. I’m new so can’t upload pics to the post but included some links below.
i scraped some solder mask off but the copper underneath is a ground plane so looks like the pad goes down to a lower layer.
can i run a wire to the cap next to it and use that instead? The caps on the APU seem to be connected - in parallel i think?
https://www.dropbox.com/s/zyouhh2v95g7uwj/vlcsnap-2023-05-24-21h57m17s141.png?dl=0
https://www.dropbox.com/s/cb2oe0if3mblybd/vlcsnap-2023-05-24-21h58m46s444.png?dl=0
