Short story: Nothing happens when power is pressed. Even after new working PSU.
More detail: Installed a new power supply after last one was shorted by Roaches. (Everything has been cleaned) It powered up three times on test bench and when disk was inserted it started to rumble so I turned off the console and manually removed disk from drive. Decided to plug it back in and try digital game but now nothing happens.
Not sure if caused by movement to the console to under TV. Other PS4 pro works using same cables and spares but the repaired one doesn’t work with any.
There is no beep, no flash, no hard drive spooling, nothing at all.
Not sure if necessary but “Long Story”:
I got this PS4 Pro from a guy who had a bad trade (traded his One S for the Pro), turns out it has a roach infestation and didn’t work. It would beep but turn off. He made a post about it on FB market place and said it was garbage. So before he threw it away I asked if I could have it and he did give it to me for free. I first noticed the system has been opened before due to the prongs on the back where broken off and the hard drive was missing it’s screws and was loose in the garbage bag he put it in. But I ended up having to remove over 60 roaches from the thing and clean it and noticed one had popped on a part of the PSU. So I ordered a new one for the system and when I replaced it it booted up fine. I performed an update and got several games to download. (Didn’t even think to put a disk in.) Games played fine, no load fan noises and didn’t over heat. But then I remembered I didn’t test a disk and put one in and Jesus did it rattle. The disk didn’t eject and just made clicking sounds so I turned of the console and unplugged it and manually removed the disk and it came out. But as soon as I plug it in nothing happens. I tried a new power cable, HDMI cable, and tried putting the disk into the bay to see if it would boot up but nothing is happening. Not sure if the movement of turning it over to remove the disk broke something or not or just the new PSU is now dead.
Sorry for the long story but it’s been absolute hell.
