Little note. I DID NOT GROUND MYSELF or anything to ground myself. I know! I’m stupid. I did unplug the battery to be safe. “I” wasn’t safe enough though.
After I blew off the dust i started messing with the ram card because i wanted to take a closer look at it but the black flimsy film protecter was “stuck” on the ram. I was able to peel the film off and pull the ram card off… Forgot that I was suppose to lift and pull so that could be why it won’t turn on. Although my last mistake might of killed my laptop. I didn’t get all the dust off. There were still some in between the fan blade so I decide the take 8 or 10 screws that was holding down my two fans, copper tubes, and heat sink. I lifted it up to find my processor and other things that had thermal paste on them. The late realization of what I had done I put EVERYTHING BACK! Did not care for the small bits od dust in between the fans. Tried turning it on. Didn’t work. Plugged the power supply. Nope… (Groaning in stupidity)
Can this be fixed or am I doomed?
