I was playing my switch and it just went black. It works perfectly fine on the docks but I’m not that good with electronics so I don’t know how I’m supposed to fix it. Any help?
If you shine a bright light on the screen can you see anything at all? Or can you tell if the backlight is on?
I just tried it completely Black
Has it been opened prior?
Nah I haven’t Idk what could be the problem
If it’d been opened then I’d bet it’s the LCD connector (bent pins) but if not then your not left with much to go on… If impact was the cause then a torn backlight ribbon or broken filter (if applicable on your board rev) near the LCD conn would be my best guess or just a bad LCD in general.
You can repair the first two with soldering iron / experience. The last in replacing the LCD panel is just a pita
