The power supply in my son’s PS4 Pro popped and then the whole unit went dead. I have removed the supply and verified that it has no output (nothing on the +5VSB output). There are several repair references that I have found but they are all for the ADP-300CR version of the power supply which has a visibly different power supply PCBA. On the 300CR it appears that a common failure is a resistor near the high voltage cap in the middle of the board. A similar resistor on my PCBA appears to be open (R111). It is marked F1J 0.1 ohm 76 U. It is a larger white device and I suspect a fused resistor. I am looking for any help identifying the proper cross reference to order a replacement (fuse current). If anyone has any suggestions I would appreciate it.
Thanks,
Dave
