Hello. My 6 year old finally showed interest in my switch. Anyway, he wanted to “clean” the screen and got the system wet. Screen went out and fan was running at full speed. After forcing it off I let it dry. Today I opened it up and aside from a few drops of dried liquid, I found what looks like a blown cap.
I would like to try and replace it but have no idea what specs it is. It appears to be on the underside of the memory.
I cannot embed an image as I am a new user but any direction where i can get more info or if i can send an image through a direct message
I guess the first thing to do it clean up the corrosion (in all areas) with some IPA and see what damage there is underneath.
You can then start measuring things. The coil in question should have continuity through it, so start there, but it could have blown the backlight IC next to it.
