I am hoping someone may be able to help me. I have bought a broken switch off eBay that has a charging problem, it will register that it is charging but the charge will not go up. I opened the switch up and found that one of the resistors above the BQ24193 chip was missing. I have read and found that it is the 5.6K resistor that is missing. I’m new to all this and not sure what I need to order hoping someone might be able to point me in the right direction.
I would not suggest DIY if you not familiar with soldering. Those are 0201 size smd resistors.
Or maybe you don’t really care of failure then this might be a good chance gaining exp and practice on precise soldering.
5.6k ohm 1% or 5% 0201 size resistor is the BQ ic top left horizontal resistor.
Additional solder flux, solder and fine soldering iron tip would make this work easier.
Thanks for your reply! I am confident in my soldering and have everything I need to do the repair! I’m just not too familiar with all the different parts so thank you for helping me out, much appreciated!
