I was wondering if anyone has a suggestion for what temperature to remove the switch digitizer at using a heat mat? I’ve heard up to 80C for phones
I’m assuming you’re using a similar heat mat as this https://amzn.to/2LWALMV
When I use it for Switches I have it set on 65C. You can have it hotter or less hot but you would vary the amount of time it was on the heat. 80C would probably work fine but keep in mind that high heat can cause the adhesive to sort of bubble a bit on the edges of the digitizer so I keep it on the heat as little as possible while still softening the adhesive.
Hope that helps.
