Classic, and worthwhile the OP taking note here and carefully inspecting all the ICs on this rail for any signs of damage as this is more common than the chips themselves spontaneously failing in cases of no liquid.
One thing I probably should have mentioned is, if your meters resistance mode has a high enough resolution you can quite often find the culprit which is causing a short to ground by simply placing one probe on ground and checking the ICs surrounding components on the same rail with the other probe, your lowest reading will indicate with high probability which IC/component is at fault.
For example, yesterday I had a short on 3V3PDR, I set my meter to resistance, I measure a 0.68 ohm short at the ENXX IC (on the corresponding nearby caps) I then do the same at the WIFI IC VIN (caps on this rail) and my reading is 0.85 ohms, etc, etc. I then measure at the large cap at the P13 on this rail and it measures 0.32 ohms which represent the lowest reading, pulled the cap, short cleared.
