Hi, I know this has been asked a a lot of times I tried posting on others threads with no replies.
Anyway I have a Nintendo switch with no hdmi output. It started out as a messed up charge port. So after changing the port, the unit won’t turn on. Replaced p13usb ic, unit
seems fine, but after testing the dock no output.
When switch is docked the screen turn black and green light turn on. But no signal.
Well I don’t have a microscope. I have lifted the p13usb twice seems to be flat. Seems like the traces are all intact. I replaced all the chokes one was bad. The dock is good. I tried a different switch and it was able to output display. IL try to check all the other components near the p13usb chip
I cannibalize a usb type c port. I have tested the pins in diode mode. I got these values on both sides of the charge port. I have ordered a break out board but hasn’t arrived yet. IL test again when it arrives
Wow didn’t know there were refurb m92t36. Anyway my unit is working now.
Turns out it was bad solder after all. It’s really hard working with just magnifying glass as I don’t have a microscope. I resolder the p13usb and viola like magic it fixed the problem.
