Hi there, I bought a switch off of eBay that “wasn’t docking” but worked other than that, the docking was the only issue. After replacing the charging port the switch now docks but I’ve noticed the switch itself doesn’t actually get recognized by my pc.
Things To keep in mind:
- the cable between the pc and switch is fine
- I believe the charging port was soldered on correctly
- the PC charges the switch when connected
Any advice? Has anyone ran into this issue before and fixed it? The reason I would like the switch to be detected is because I’d like to run CFW on it (yes it’s an unpatched unit).
