I purchased a nintendo switch to repair; I came here to ask for advice about what may be wrong with it.
Board: PWB/ AU/ CHN HAC-CPU-01
Fuse has continuity
The battery does not charge, I plugged it into the usb c charger w/ battery and left it for 30 minutes result being battery went from 4.06v to 4.02v.
There is a shorted capacitor on pin 18 of the MT CHIP
Voltage Readings (From Caps)
BQ CHIP
Pin1: 14.97 V (W/ Charge + Batt plugged in)
MT CHIP
Pin 5: 3.29V (W/Charge + Batt plugged in)
Pin 6: 3.30V (W/Charge + Batt plugged in)
Voltage Readings (From Testpads)
Cluster K (Batt, Batt+ Charger, All unplugged)
Testpad 1: 0V, 0V, 0V
Testpad 2: 0V, 0V, 0V
Testpad 3: 0V, 0V, 0V
Testpad 4: 0V, 0.1V, 0V
Testpad 5: 0V, 0.92V, 0V
Testpad 6:0.06V, 14.96V, 0.03V
Testpad 7:0.05V, 14.97V, 0V
Cluster L (Batt, Batt+ Charger, All unplugged)
Testpad 1: 3.61V, 3.60V, 0V
Testpad 3: 3.61V, 3.61V, 0V
Testpad 5: 0V, 0V, 0V
Testpad 6: 0V, 0V, 0V
Any idea what’s wrong?
Note: I’m going to disassemble the unit today and look around even more, just held off on that in case there was anything I need to check with everything plugged in.
