Nintendo switch oled problem after installing a modshio
I have problem with nintendo switch oled after installing Modship, it working only on dock mode , not working in handled mode , I tough that the problem is with |FPC connected , I just changed it but still same issue . please advice
the ship bootiing propertly Blue then green on the same console
also I have tested the tps65633, and checked all the motherboard under microscope no bridges , also tested the continuity of all testable pin in the lcd ribbon , all is fine ,also no short on the ribbon IC , no visible physical damage , please advice
Thank you .
Would guess that maybe some pins on the FPC connector where the display will be connected on the motherboard are defect.
