Unpatched Nintendo switch.
was shorting on m92 and p13
usb port was damaged ripped all the pads off on under side.
removed usb c port installed then installed m92 and p13. booted with a battery.
( knocked a few components around m92, but I managed to put them back)
went on to solder micro traces on port ( first time) ngl I was pleased with the result.
unsure if the inner ones are making a full connection but the console docks perfectly and I tested if there was any bridges and there isn’t.
one thing I’ve noticed and it’s why I’m here is. when charging it only charges at 0.43 amps both sides of connecter.i can sometimes charge at 0.73 amps if I fill the connector around fast.
I get 15v on my multimeter when I test the point on the forth pin??
I replaced m92 again, as I’m not a fan of my soldering on that ic, it always looks like I haven’t got enough solder onit.
But when I try and add more with a iron, I remove the resistor etc.
I reflowed bq. but it made no difference.
any advice would be appreciated
thanks.
