Nintendo Switch v1 ripped pads screenconnector
So I got my hand on a NS v1 that was completely destroyed.
  • Gamecard slot wasn’t working, touchscreen wasn’t working ripped connector - repaired and working now
  • No USB-C connector and ripped pads - repaired and working now
  • no screenconnector thing (56 pins?) and about 15 ripped pads. Anyone knows the pinout? Are they all connected?
USB-C HDMI out works now. But I don’t have joycons so can’t do much with it as touchscreen doesn’t work when docked.
If I find out the pinout I maybe going to attach 56 wires (or less??) to the screen ribboncable and board.
Not for resell or anything, just trying to fix and boost my skills.
thanks!
The two black marked pads are nc. Greens are GND and the rest are needed lines for the lcd. So if all 56 pads are ripped you have a long journey ahead if you want to restore the needed pads…
Here is a link to layer scans where you can check where the via of the pads are and in case where they go, if you can not connect to the via anymore:
https://balika011.hu/switch/
Thank you so much Calvin. I’m going to give it a try!
All repared (what a work …holy moly) but the connector won’t touch the pads…
The only connector I had broke cause I tried to push it on the pads and that white thing came off.
I tried to scrape the soldermask as flat as possible but I guess it wasn’t enough. And I also think I used a bit too thick of a wire to repair the pads 0.15mm to be exact. Good news is when I took the connector off again all the pads(including the ones I repared) were still intact.
I have to say that this is my first “micro solderding repair” , so I guess I have to learn a lot and also need some better soldertips for such soldering.
edit: not really the first thing, the first micro stuff I did was broken pins on a AMD Ryzen 7 CPU , 8 missing pins took me 3 hours to do, but quite good for a first try. The CPU is still up and running.
A good help for such tiny pad repairs a precut solder strips. They are nice flat and help to achieve a fairly even level when repairing the pads.
Yeah i have a couple of packages but for me unusable. They all bend in a circle. LoL maybe I bought the wrong crappy quality ones…
