No display , battery is charging
I’m working on an og switch, no charge no boot no display
Found a short on the PI3USB , changed the chip and the short went away
battery is charging , using a fluke on the pins showing 4+ volts
Still no battery charge symbol on the display an no display at all
Liquid indicator looks like a Petri dish
Any suggestions on where to go next
Check the M92 and BQ chip (And maybe the fuelgage).
Checkt the current draws.. Does it switch to 15V when you put in the original charger?
