Not able to Initializing my ps4
I can click on the option and it go to a hundred the it redirects be back to safe mode and it doesn’t work tried all the safe mode options no solution yet found please help
make sure your hard drive is correctly inserted, also make sure that section is clean, dirt could cause a bad connection between hard drive and motherboard… if nothing works try replacing your hard drive…
