Hi, everyone!
I’m asking help with Nintendo Switch OLED.
When I turn it on, the screen turns purple.
I replaced the 4.7k resistor—it didn’t help.I replaced it with a 10k resistor—it didn’t help.
When I booted into Hekate, it showed that the eMMC status was “critical”. I was able to back up eMMC BOOT0 & BOOT1, but can’t back up eMMC RAW GPP (error). When I try to backup the keys, a warning appears:
[FatFS] Error: BRNL
Unable to mount the system partition.
I installed an eMMC from another OLED switch, and the errors disappeared with it, but, of course, the keys don’t match.
Are there any options for restoring the original memory, or is this the end?
Wow. On Monday, when I’m at work.
Wouldn’t I have had the same problem with another eMMC if it were due to a bad solder joint? The other eMMC on this board passes all the (speed) tests and lets me make a backup without any problems.
I moved this memory module to another board that was 100% functional and got the same error. So, if you see the following in
hekate → console info → EMMC:
Maintenance: Auto: Critical
then your memory card is dead.
