Hi, my OLED switch board has 2 bad capacitors, here’s the attached photo of the 2 capacitors. Does anyone know how to get replacements? Thank you a lot!
(Apparently I can’t embed images or links, so here’s imgur link, please replace (dot) with .)
imgur(dot)com/UuOzc2b/
The caps are near the ALC5639.
The both cap should be 0603 22 µF.
i cannot find 3.3v versions just 6v or 10v does it matter ?
The rating is for max voltage. For a 3.3V rail you can use 6.3V rating or above.
thanks for the reply
i replaced the capacitors switch turned on cudnt read a game and then switched and wont turn back on i inspected the board theres no scorch marks or fire smell is it dead do you think ?
