OLED Switch not turning on gets power picofly blue then green
Bought the picofly chip to do an installation on my Nintendo Switch OLED, (First time doing a work of microsoldering), I installed the chip everything went fine got to the NO SD CARD part of the picofly it booted but when I tried to re-assembly it suddenly I had no boot image the picofly went Blue then green but no image, the APU doesn’t get hot there is no boot but there is power one thing that happened was that the EMMC Shield got knocked out beneath the board when I assembled it and it had power going through so I think it shorted something close to it? How multimeter doesn’t show a short in nearby capacitors
Hello,
I’ve got the same issue lately, try meassuring the DAT0-point in Diode mode (Red to GND, Black to DAT0) while the Switch board is charging. This should giv you a value between 400 and 800. If it’s anything above or below, disassemble the DAT0-Adapter and reassemble it.
