I have a OLED Switch Mainboard that had a dead short on the big cap near the USB Port and some other caps around the board.
After measuring I conluded that most likely the USB Port is bad, even though there was no visible damage. I’ve desoldered the Port and most of the shorts were gone.
Around the MAX77812 I am still left with some shorts to GND on the caps left of the IC. (I am not allowed to Upload Images, a liitle hard to explain without)
Measuring 17.9 Ohms to GND and 0.3V in diode mode.
The switch is booting normally with a known good battery. I didn’t install a new port as I am still waiting for them to arrive.
Are these readings normal, or is there further damage I need to check. Should I replace the MAX IC, or can you point me to somewhere else I should check?
