Hello,
Since few days i try to repair a Nintendo Switch which cause me many problems.
The switch had no reaction at all ,even with a new battery. The charge port was damaged.
I changed the USB C port and the M92T36 but no reaction at all.
I search shorts on MB and i found many shorts around the M92,P13USB.
I remove the P13USB and shorts are again here.
Red circles on images represents shorts. I added a non fonctionnal filter near the P13USB.
I have no idea with this problem.
Which component could cause this?
Have a good day!
Just realized you already tried removing the P13USB chip. From what I understand and read online, if that’s bad (short still there after removing it), it’s irreparable. I could be wrong though.
Hello,
Thanks for you answer. Could it be eventually a problem with the Max77620 component?
Have a good day!
You might want to check the enxx ic above the big audio ic too. That chip is on the 1.8v rails as well
Hello,
Thanks for your answer. Have you a photo of the place for this component please?
I am not yet really familiar with all these IC
Thanks a lot!
Im away this weekend but north of p13usb is the big audio chip. Right wbove that is the enxx ic(small square)
Hello,
I will take a look.
Thanks a lot!
