PS 5 Single beep BLOD UART unknown error
Hi,
I have a PS5 on my bench with single beep BLOD. It flashes blue light for around 3s and then goes off. Second try is beep only (Init phase only). Then third again 3s.
All fuses are good. Init phase is 311mA then 7mA. Good so far.
Thermal cam Shows every relevant component flashes warm and then shut off. RAM, CPU, SSD Controller, Rail Mosfets.
UART is Not helpful, After clean and test only one error:
00 30.10.2024 20:47:08 80801610 High Not found in list. Report Findings.
Click Here To Report
|-(OK 00000000 80801610 1822FABD FFFF0005 00000100 2013 003E 2045 17CE:63)
So nothing i can deal with. Any ideas?
Thanks and Best regards!
Andi
I would check RAM GDDR6 #5 and replace it direct
or swapp it with RAM #6 and see if the error is than 80801620
Hi Calvin,
You are such a helpful guy, thanks for sharing!
I will give it a try.
Did your solution came from coders uart list that 80801610 is maybe part of ddr failures?
Thanks in advance and best regards
Andi
Phil and my list has the same origin.
That the 808011xx and the 808016xx codes have the same logic, is an observation from three or four cases I collected over the last time.
If a replacement solve it or a swap alter the error code please share your exps.
I will First try To swap for getting more confidence on the error Code and its root cause.
I will document my observations here.
Hi together!!
Good News, swapped RAM 5 with one from a Donor and now it is back to life again!
Thank you so much, so the 808016xx are RAM Faults as well.
Can we document this in a good way (for Console Tool as well?)
Thanks for your help an Best regards!
Andi from FiXiNGA
