Hello awesome people, I am in a strange scenario. I am trying to repair a ps4 controller, but I am currently out of options. Everything works fine with the controller until I disconnect it from the usb cable. Then the controller is just dead. I thought it would probably have to do with the ps button or the battery. I have tried different batteries that I know should work, but unfortunately still have the same issue. Also the ps button seem to work just fine when connection to the PS4 or a pc with the usb cable. I have tried the different reset options but nothing works. The only thing I could think of right now is that there could be a broken trace or something, bit so far I haven’t found the culprit yet. I tried to compare the motherboard of a working one versus the broken one, but have not yet found a difference when checking for continuity. Does anyone has a suggestion or perhaps encountered the same problem but was able to fix it
Thanks!
