I have multiple controllers have dead IC, S2PG001 and as the iC itself is expensive i found an alternative, some repair guy i know posted a video of replacing IC with TP4056 , and it works, i asked him about it to learn it, said I won’t share any knowledge and you have to send me the controller to fix it to you ( he’s not scammer as he’s famous in my city for repairing and actually repaired couple of things with him) so i tried to copy his work, the controller started charging the battery but the controller won’t recognise or connect to ps4 or pc , so i think there’s something else to it not only charging the battery with TP4056 so I’m trying to figure out how make controller connect without using IC, some bridges or resistor to data?
Hi i think you fix the problem can you share with me how you fix it
