Hello Guys, had someone the same issue?
Ps4 Pro 7216b
F6202 replaced after that I powered it on and tried to insert a disk, nothing happens. Then I checked the fuses again, F6202 blown again.
I replaced it again, but it keeps blowing… Replaced the fuse about 3 times. If I try to insert a disk when the console is off it powers on, but no disk feed. I’ve also replaced the entire disc drive, nothing happens.( I’m not sure if the replacement does really work).
Any ideas? Cheers
