Grizmo
              1
              Hi
I have a peculiar problem my PS4 immediately turns off when powering on the monitor or tv.
Otherwise when disconnected from the monitor it works absolutely fine.
I have replaced the power and hdmi cable cleaned the vents but to no avail. Sometimes it stays on about 2 3 days the again the problem occurs.
Any solution to the problem?
              Thats a setting. If you go into settings, system, and then make sure enable hdmi device link is unchecked.
                Grizmo
              3
              Ok thanks will try but it started occouring all of a sudden after 6 years??
                Grizmo
              4
              Enable hdmi device link is already disabled?
Then what should be the cause?
