PS4 Slim Disc Drive problem. Power but won't work
My PS4 slim was working perfectly fine and I cleaned it for the first time ever today and I followed a video to the t and messed nothing up nor had problems. Now the disc drive is having problems. Everything is where it’s supposed to be but when I put a disc in it will beep the laser might move back a inch then go back forward and it will start buzzing for a couple seconds. And I can’t find anything on the Internet that helps. Also, I don’t want to mess with any fuses or the motherboard.
reconnect all disc drive cable, plus cleaning inside drive if possible. If none of this work, you likely need a new disc drive laser header
Alr ill try that now. The only part I didn’t do was take out the entire doc drive.
Yooo jkyoho thx so much for reminding me about the inside of the disc drive! It was the black rubberband that became dislodged in its spot and I just needed to put it back. It wasn’t my PS4, it was my grandma’s and I was in a world of hurt if I couldn’t fix it since I was the one who messed it up when I was cleaning it.
