Hi There
Hope somebody is able to identify some components for me.
It is the two capacitors on both sides of the fan connector. See picture.
h
ttps:
//ibb. co/MxStqwkF
Thank you for your time.
Hi There
h
ttps:
//ibb. co/MxStqwkF
100nF, missing caps wont stop fan spinning though
Thank you for your quick response. Voltage? There must be some more problems with this board - interesting ![]()
If you have checked diode reading on Vcc and PWN PIN after the connector repair and fan still not spinning, you might have issue on southbridge(pwm signal straight from southbridge)
