PS5 CFI-1216A 1 Bepp No Light EDM-033 mobo
So I have bought a dropped PS5 very cheap, I plug the power and I get 1 beep no light, the liquid metal didn’t escaped, I did a UART diag with consolerepair tool and this is what I’m getting(the motherboard is EDM-033)
[Slot #] [Date Time] [Error Code] [Priority] [Error Message]
00 03/08/2026 22:13:25 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0042 10000000 217C 0000 FFFF FFFF:28)
Click for TSB Information
What I have tried so far
  1. ⁠i have checked F7001 and F7002 fuses
  2. ⁠i have checked for shorts around WiFi IC
  3. ⁠I have found online an almost similar board(see the attached images) and checked the voltages for NUVOTON HDMI IC and
    5V STBY is present
    3V3 STBY is present
    0.9V PWR(when I press the power button) is missing
    1V8 PWR is missing when I press the power button and also there’s no short
    On SSD Controller everything is fine when I press the power button
    5V is always present there
    and the rest of my noted voltages are coming up for 10 seconds there but then 0
    What else should I try? This error is driving me insane​:weary_face:
What is the power sequence from the board if applied 12V?
A healthy sequence should look like that:
