PS5 Digital EDM-030 2SEC BLOD
Hello People from Tronicsfix,
I have a PS5 Digital which had a blown F7003, after replacing it the console now beeps and gives me a blue light for 2 seconds, I read UART and it gave me errorcode 80800022 indicating bad connection between gpu, ram etc. Tried pressing on ram but its a bit hard to press all 8 chips while trying to turn the console on aswell. Anyway, does anyone have an Idea what I could try next?
I checked the apu imo it looks OK
Greetings,
INH
Fuse blown for reasons, have you checked if there is any short on the F7003 before putting new fuse on?
Yes there was no short, I injected into the other side and saw some heat from the voltage regulator and controller but this is because they are turning on from getting voltage, I can check again with removed fuse?
Hi, did you ever fix this?
Have a similar problem.
