PS5 Dualsense Charging Station - broken connector/prongs
Does anyone know how to replace these connector prongs or where to find replacement ones? I have 2 that are broken (one for each slot) and I’d like to replace them without buying whole new unit.
I have been looking for those prongs, but no luck so far. The good thing is, the right-most one is not necessary for charging so you can open up the connector and replace the broken one with it. I’d even bet the second-right is not connected either.
After removing the tiny PCB with prongs I unsolder the wires and the broken prong. Then put fresh solder on its pad, grab the good prong with thin tweezers, and heat the pcb from the bottom to pick it up and move it to a new spot. Solder’s surface tension will make help in positioning the prong properly.
