When supplying 12V to the board, the current consumption initially jumps to around 50mA, then quickly drops to about 6mA and stays there.
When I first started working on this board, the DA9065 was not producing 3.3V, so I replaced it with an RT5126. After the replacement, all standby voltages are present and no fuses were (or are) blown.
Since this did not solve the issue, I attempted to use UART, but I cannot get any communication. Both TX and RX lines have 3.3V present. So I taught maybe Southbridge is faulty, I tried two different Southbridge ICs, but the behavior remained unchanged and UART is still non-functional.
I checked that standby voltages around the HDMI IC and Wi-Fi module are present.
Using a thermal camera, I can see a very faint warm spot on the Southbridge.
Has anyone encountered a similar fault on an EDM-020 board or have suggestions on what I should check next?
