PS5 EDM-030 | Error 80810001 / 216D
No shorts detected. All other voltages are present.
The thermal camera shows that the APU stays cold.
No voltage is generated in the area circled in yellow.
Any suggestions on what could be causing this?
Thanks in adva
nce!
Did you search the backside for shorts or low resistance? Shorts or other failure can be on the opposite side or in another area. fuses checked?
