I have a PS5 EDM 033 board that no beeps or signs of power. Found a short on the ethernet port chip and traced it down to the southbridge chip. Removed it and the the short went away. I replaced the SB chip with the same kind and it powers up like normal and everything works. Has WIFI and everything. Now the issue is after a few minutes the console freezes. The game light is still on and power button wont even turn it off. I would have to unplug it. It seems like is getting to hot. I did clean/polish and reapply the liquid metal. Fan does runs when its on. Anyone have any ideas on what it may be?
Just an update. Got it working.
Hi, would you mind sharing what the fix was, even if it was something simple? I’m having a similar issue, and it looks like the console’s SB has been replaced by someone at some point. I’d really appreciate any insight!
I reballed the southbridge. And used very very little flux and resolder it back on. I believe that was my issue. To much flux under the chip. I have seen videos of people reflowing the chip and blowing it out with air in a can. Hope that helps you out.
