Hi guys. Total noob here to the PS5 board repair scene. I have an EDM-033 board that gives the one beep no light error. My knowledge is very limited concerning the process of diagnosis and possible repair of the system. I have used UART and below are the errors:
[*] Operation: Run Read Error Codes
[Slot #] [Date Time] [Error Code] [Priority] [Error Message]
01 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
|-(OK 00000000 80910002 FFFFFFFF FFFF00F6 10000000 2186 0000 FFFF FFFF:34)
Click for TSB Information
01 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
|-(OK 00000000 80870003 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:45)
02 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
03 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
04 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
|-(OK 00000000 80910002 FFFFFFFF FFFF00F6 10000000 2186 0004 FFFF FFFF:38)
05 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
|-(OK 00000000 80870003 FFFFFFFF FFFF00F6 10000000 217B 0004 FFFF FFFF:49)
06 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
07 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
08 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
09 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
0A 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
0B 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
0C 7/2/2026 1:13:21 PM 80910002 Severe Known Unknown 80910002 (SSD Controller) - Possible 504X 2v, Power Failure - Check Fuse F7001
0D 7/2/2026 1:13:21 PM 80870003 Severe Flash Controller - Flash Controller Boot Failed - Flash Controller Boot Failed : Couldn’t read Chip Revision. Post Secure Loader Error - Check fuse F7001 - (No beep, no light)
0E 7/2/2026 1:13:21 PM FFFFFFFF Low No Errors
|-(OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A)
I checked F7001, it was blown. I replaced it, cleared the error logs, tried to boot the system…that was unsuccessful. Checked UART again…same errors. I also did some probing and both 5V and 12V are present, did not locate any 3.3V. Any guidance on how to proceed, greatly appreciated.
