PS5 EDM-033 Short on Rail near APU
Hi everyone,
My EDM-033 is reporting the following errors over UART:
00 16.07.2026 21:24:02 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 1B559DF8 FFFF0023 10000100 2141 0036 FFFF 1D00:81)
Click for TSB Information
01 16.07.2026 21:24:02 C00C0002 Severe VRM Controller Failure, Check Mosfet (6414A) Located Side-A, Below Sony Interactive Entertainment Inc. Check Infineon XDPE14286A 16 Phase PWM Controller - Located Side-A, Right of fuse 7001 - Single Beep, 1 second blue light, off.
|-(OK 00000000 C00C0002 1B559DF8 FFFF0023 10000100 2141 0036 FFFF 1D00:97)
I measure 23 Ω to ground on pin 9 (SDA) of the XDPE14286A and 0 Ω to ground on pin 19 (VDDIO), as shown in picture 2.
I also measure 0 Ω to ground on a rail near the APU (red arrow in picture 1).
I removed the XDPE14286A, the inductor near that APU rail (marked with green squares), and the two capacitors (green arrows), but the rail still measures 0 Ω to ground.
Can anyone tell me where this rail goes and which components it supplies?
I injected 1 V into the rail at around 2.5–2.9 A, and a hot spot appeared on the APU. It seems like the APU itself might be shorted. What do you think?
“I think the APU is faulty, right?
If the APU lights up at a point on the edge, the edge is in most cases damaged/chipped. I guess game over.
