PS5 edm030 one second blue light and off
Liguid metal spilled to near 6 phases when shipping to a friend. Bottom part in the pictures. Four big capacitors are short near fuse F7501 but themselves are good. Just measured short on board. Uart checked
Error Code: 80060000
Cause: APU VRM (6 Phases) Power Fail, Check Infineon XDPE14286A 16 Phase PWM Controller
I injected 1 voltage to the coil near F7501 didn’t find hot spot. So I thought that four caps are not shorted themselves. Do I increase voltage to 2v and check? Or pull them off one by one and find which one is short? What else do I have to check for the Dr MOSFAT?
In general: Increase the current not the voltage. Stay at 1V and start at 1A and see what the current draw is. If it reaches 1A and nothing is getting hot, increase the current to 2A than to 3A.
The 5V_MAIN line is feeding the eight VRMs, 5V-USB-C-power-output, Second Front USB power, 5V-disc-drive-power.
My guess: there are leftovers from liquid metal spill at the VRM which cause the 5V_MAIN to short to ground.
Many thanks man!
It turns out that four big caps near F7501 are not shorted. I double checked them and they are fine.
I have found all eight DrMOS with two pins have higher solder bead than rest of the pins.
So I used thermal camera and press power button two DrMOS turn red so I think these two DRMOS power IC chips AYb0 or AYBO are the problem.
The rest six are fine I think. But I will buy 8 instead.
the top two mosfets are for Vcore, they start to work straight after SOC/APU call to turn on, where the rest 6 mosfets are VGFX core, most of them underload when game launch but the rest of time they are in idle stage.
If you dont see any mosfet runs over 80C at idle or 100c under heavy load Game, you might need to look for somewhere else
FYI the solder blob/balls on the output side is kind of normal, I have seen few working/non-working board came like that from factory, there are 8 pins (Vsw_16~ VSW_23) interconnected so likely factory solder paste would eventually came into a ball randomly onto one pin.
Thank you so much. I will look for somewhere else. I think the 2 phases DrMOS are fine. Current stops at 6 phases.
If one of the caps is causing the short, the cap is usually lighting up like a christmas tree at voltage injection.
Please post a picture from the other side of the mainboard at the same spot.
I don’t know which point to inject voltage. Don’t want to burn the APU or cause more damage.
I have found this pin has very low measurement in diode mode. Only 0.075v Voltage drop compare to working board of 0.375v.
It only goes to the two resistor and a small cap on the trace next to the xdpe chip
Is this the actual state of the backside of the mainboard with liquid metal still spilled over the board?
If so, you have found your issue. Liquid metal is conductive and shorting ever line which get in touch together.
Yes. That is how the liquid medal spilled on the board when I opened up. This board has never been touched before.
Edited: Sorry, this second pin is actually not normal. Pin57 or Pin2. Diode mode measurement 0.87v voltage drop. This pin is connected to the capacitor on the other side of the board. Good working board should be 0.358v.
I dont any have EDM030 by hand, but from 010/020 boardview, this pin56 is Vcc 3.3v_VRM and it should be generated by a SOT23-5 chip from 5v_main/standby
It is likely coming from this chip pin5
Finally fixed it. Replace a PWM chip from a donor board. Same marking sy03. I believe there are also sy01, sy03 and sy04 in the market and they are not compatible each other. And if it is new chip it has to be programmed?
And I also clean the liquid medal where the needle pointed as I did it notice that at the beginning.
