PS5 error-> CE-108262-9
Hi everyone from Germany :waving_hand: i hope you are fine :slightly_smiling_face:
I have a PS5 with an EDM-010 motherboard. The console shuts down completely after about 2–3 minutes, even when no game is running.
After turning it back on, the error CE-108262-9 appears in the system error history.
Sometimes, if I try to turn it back on immediately after the shutdown, it does not boot normally. It only shows a blue light for about 2–3 seconds (BLOD) and then shuts off again.
UART:
[*] Operation: Run Read Error Codes
[Slot #] [Date Time] [Error Code] [Priority] [Error Message]
00 25.09.2026 22:54:10 High Not found in list. Report Findings.
Click Here To Report
|-(OK 00000000 80802205 1BB74B66 FFFF0005 00000100 2013 0036 3EC8 1DED:7F)
Click for TSB Information
01 25.09.2026 22:47:53 80802205 High Not found in list. Report Findings.
|-(OK 00000000 80802205 1BB749ED FFFF0005 00000100 2013 0036 3ADA 1D98:81)
02 25.09.2026 22:45:42 80802218 High Not found in list. Report Findings.
|-(OK 00000000 80802218 1BB7496A FFFF0005 00000100 2013 003E 3C98 1D84:6B)
03 25.09.2026 22:44:55 80802205 High Not found in list. Report Findings.
|-(OK 00000000 80802205 1BB7493B FFFF0005 00000100 2013 003E 401D 1D40:4F)
04 25.09.2026 22:43:38 80802205 High Not found in list. Report Findings.
|-(OK 00000000 80802205 1BB748EE FFFF0005 00000100 2013 003E 40EA 1D8F:8E)
05 25.09.2026 22:43:04 80802205 High Not found in list. Report Findings.
|-(OK 00000000 80802205 1BB748CC FFFF0005 00000100 2013 003E 41E8 1D9C:80)
06 11.09.2026 17:57:30 80802205 High Not found in list. Report Findings.
|-(OK 00000000 80802205 1BA490DE FFFF0005 00000100 2013 003E 194D 13A2:62)
07 11.09.2026 17:56:43 80802218 High Not found in list. Report Findings.
|-(OK 00000000 80802218 1BA490AF FFFF0005 00000100 2013 003E 187B 1386:5F)
08 11.09.2026 17:56:14 80802218 High Not found in list. Report Findings.
|-(OK 00000000 80802218 1BA49092 FFFF0005 00000100 2013 003E 1818 1353:2D)
Click for TSB Information auf D
Has anyone seen UART codes 80802205 / 80802218 before, or had a similar issue on an EDM-010?
Hi. I have same issue on a slim ( the model that have realtek HDMI ic ). Same behaviour, same kind of error codes, 80802217, 80802205, 8080222A and 8080222B. mostly it’s 2217.
