Hi there, i have a defective PS5 (EDM010, 1016A) here. It showed no Signal and i changed the HDMI Port. Picture is back now and as i startet to Update the console, the update interuptet with the SU-101312-8 error. From this point console only starts in safemode. I have no chance to update it.
On the board ALL (!) fuses are not blown. All voltages are available. But there is no 5V measurable at the 5V Pin to the drive. 12V is present. Wenn measuring in standby it says 2,5V at 5V Pin, as soon i turn console on it says 0V… But in standby this 5V Pin has to say 0V or what?
However, the drive does get 12V but not 5V.
Additionally, pressing eject button does not make a sound.
At the fuse F5401 is a switch ic (SI3493DDV) and a transistor (DTC044).
I would check at the switch ic if 5V at the left side at the blue marking and if 3.3V at the enable pin (red marking) are present when PS5 is on.
That should switch the input to the output side (left to right at blue marking).
Hey Calvin greetings! Sorry i didnt expect another answer here. Two days ago i found the solution:
The original ribbon cable of this PS5 was broken, So i used a new one after i repaired the HDMI Port and made the testrun. After the testrun the drive was still dead. This week somebody told me 5V will not go to the Pin if the drive is not detectet. Than my idea was to try a third ribbon cable. That was the good idea. after using another used ribbon cable the 5V and the 12V are back and the console and the drive worked finde. So for future don`t rely 100% on new part like ribbon cables.
